67 Power steering hose bracket location ?
Results 1 to 3 of 3
Thread: 67 Power steering hose bracket location ?
  1. #1
    Join Date
    Aug 2003
    Location
    Texas
    Posts
    718
    It now seems obvious that the location of the PS bracket and the pathing of my power steering hoses are not correct.
    They are going past the exhaust manifolds then through the bracket then to the power steering valve.
    When looking down into the engine bay from the driver side the bracket an hoses are facing up towards me next to exhaust manifolds
    In most pictures it looks like the hose bracket is point down with the hoses being just above the bottom of the oil pan and the path of the hoses coming up near the oil filter then connecting to power steering pump.
    This all makes sense to get the hoses away from the manifolds.
    My problem is I can't find where the hose bracket would mount to path the hoses that way
    Would any one be able to share any picture of where that bracket is mounted...
    Thank you
    Standard 67 289-4v
  2. #2
    Join Date
    Apr 2011
    Location
    Niceville FL
    Posts
    4
    Re: 67 Power steering hose bracket location ?
    What you describe is correct for a small block engine. On big block engines, due to the wider engines and manifold, the had to reroute the hoses down under the engine bay.
    There should be two rubber retaining straps holding the hoses away from the manifolds. They were made from old tire casing and are almost always long gone. Unfortunately they are not reproduced..
    I have some great pics to show the correct 289 routing, and if you look closely you can see the straps. Unfortunately I can’t get them loaded. I need more posts it seems.
  3. #3
    Join Date
    Apr 2011
    Location
    Niceville FL
    Posts
    4
    Ok figured out how to post pics
    Click image for larger version.
    Here is another pic.
    Here are are some old straps
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
    Bookmarks
    Posting Permissions
    • You may not post new threads
    • You may not post replies
    • You may not post attachments
    • You may not edit your posts
