73 Cougar - 6R80 Swap
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Thread: 73 Cougar - 6R80 Swap
  1. #1
    Join Date
    Aug 2007
    Location
    Reno, Nevada
    Posts
    140
    It's been a while since I posted! My current transmission, a AOD/4R70W hybrid, has been bothering me in that I don't have good control over the shift points. I have decided to swap in a 6R80 transmission now that bell housing adapters are available. I haven't seen really any info on swapping these transmissions in to classic cars, so I will document the process here.
    I purchased the following:
    2014 F150 6R80 Transmission
    US Shift Quick 6 Transmission Controller
    Performance Automatic 68507 SBF to 6R80 Bellhousing Adapter
    Performance Automatic 68509 6R80 Torque Converter Adapter
    I'm still on the fence with the shifter. I will try to adapt the factory shifter to work. If it doesn't, I will use the Lokar Electronic Sport Shifter.
    The transmission mount will require fabrication. It's totally different from the C4/C6/AOD/4R70W mount - and several inches to the rear.
    Initial thoughts:
    - The 6R80 bellhousing is very similar to the SBF size - so there's no real concern here
    - The 6R80 body is significantly larger than a AOD/4R70W. I will need to relieve the tunnel near the old trans mount area. It does fit though!
    - The transmission mount differences don't appear to be major. I can definitely fab a mount.
    - The 6R80 does not have a slip yoke. I need a telescopic driveline. More on this later.
    - The 6R80 has no mechanical speedo hookup. Not a problem. Speedhut sells a mechanical driver that takes an electronic input.
    - The Performance Automatics 68509 kit lets you use the stock 6R80 torque converter.
    I will keep this updated with my progress...
    Pulling the AOD/4R70W out
    Old and new
    Bellhousing and adapter - the size is very similar
    Adapter installed
    Transmission test fit
    1973 Mercury Cougar XR7 Hard Top - Ford Bright Red w/ 1/2 vinyl top. 552hp/566tq 427W. 6R80 Transmission.
    1981 DeLorean DMC-12 - 300kW electric conversion
  2. #2
    Join Date
    Jan 2002
    Location
    Camano Island WA.
    Age
    66
    Posts
    4,058
    Blog Entries
    2
    Re: 73 Cougar - 6R80 Swap
    I'm looking forward to the rest of the build. How many forward gears does this transmission have?
    Hidden Content
    See ya on the hiways, Neal
    1970 XR-7 Hard top White & Ginger. 351W "Ginger"
    1970 XR-7 convertible Blue & Black 351C 4V
    1971 XR-7 Bright Blue with Blue Up beat interior
    1970 Standard 428CJ Competition Yellow The New Money Pit.
    2002 Miata LS Emerald Mica Daily driver.
    2006 Ranger Sonic Blue, 4.0 V6 5 speed AOD The work force.
    If it ain't broken, Modify it!
    Hidden Content Hidden Content
  3. #3
    Join Date
    Aug 2007
    Location
    Reno, Nevada
    Posts
    140
    Quote Originally Posted by badcatt View Post
    Thanks! It has 6 forward gears - 2 overdrives.
  4. Remove Advertisements
    MercuryCougar.net
    Advertisements
  5. #4
    Join Date
    Aug 2007
    Location
    Reno, Nevada
    Posts
    140
    It fits! I have a minimum of 1/2" clearance after removing a portion of the factory trans mount reinforcement. I'm designing a rear trans mount to bolt to the subframe. It also appears I can use the factory shifter.
  6. #5
    Join Date
    Feb 2010
    Location
    Ft Laud Fl
    Posts
    938
    As we always say, your never really done tinkering with these old cars glad your posting your project I gave up on you since you quit the blog updates Some really good info on your trials and tribulations working on your phatcat
    2008 Suburban Daily Driver
    1973 XR7 Vert 351Q
    Ex 1967 Coupe
    Ex 1972 XR7 Vert
    Ex 1975 XR7
    I know I have the right to remain silent, sometimes I just don't have the ability
  7. #6
    Join Date
    Aug 2007
    Location
    Reno, Nevada
    Posts
    140
    Quote Originally Posted by CatsRock View Post
    Haha I really should update that. It got to be a chore so I gave up. Then I got too far behind. I'm trying to be better about documenting my projects now
    I think the main things I added to the car were Traction Control, Launch Control, and this 6R80 (now). I did make a cool little dashboard display to show me all my stats - installed where the factory clock is. I sort of checked out for a bit and build some other projects. I made a reverse trike and for the past 18 months have been building an electric DeLorean.
  8. #7
    Join Date
    Feb 2010
    Location
    Ft Laud Fl
    Posts
    938
    [QUOTE=gotgraham;995313]Haha I really should update that. It got to be a chore so I gave up. Then I got too far behind. I'm trying to be better about documenting my projects now
    No worries Jacob, I was just busting your chops a little I know its a pita taking pictures and documenting steps while trying to get stuff done. Glad your still sharing your phat cats with us.
    1973 XR7 Vert 351Q
    Ex 1967 Coupe
    Ex 1972 XR7 Vert
    Ex 1975 XR7
  9. #8
    Join Date
    Mar 2001
    Location
    Brisbane, Australia
    Age
    69
    Posts
    5,846
    wow - do you have a write up on the delorean conversion?
    Leon
    Brisbane, Australia
    Hidden Content
    Designed to be driven
    Hidden Content
    Hidden Content
  10. #9
    I like this. These newer transmissions are so much better then the old stuff, Glad to see someone making the available controls and adapters to makes these work on older stuff
  11. #10
    Join Date
    Aug 2007
    Location
    Reno, Nevada
    Posts
    140
    Quote Originally Posted by leonbray View Post
    Sort of. You can follow my instagram @gotgraham - I've been posting the updates there. I did start posting some on DMCTalk - http://dmctalk.org/showthread.php?17...wered-DeLorean
  12. #11
    Join Date
    Aug 2007
    Location
    Reno, Nevada
    Posts
    140
    Updates -
    I designed a new shift lever (for the transmission) and a cross member. The cross member is made of 3/16" 304 stainless. It seems to all fit well. I designed it to interface to the Stifflers Suspension insulator - https://www.summitracing.com/nv/parts/ivp-tm-m06 I also had the new driveline made (not pictured). I'll get some better pics up in the next couple days.
  13. #12
    Join Date
    Aug 2007
    Location
    Reno, Nevada
    Posts
    140
    More updates. The transmission and driveline are all bolted in. I had some issues with the torque converter snub to crank pilot distance. Ford made some inter-year change to the 6R80 TC design, so the depth changes a little. I modified the pilot adapter on the lathe and shortened the TC snub. All fit fine after that.
    You can see the TC stud spacers here. These account for the adapter plate.
  14. #13
    Join Date
    Aug 2007
    Location
    Reno, Nevada
    Posts
    140
    Update!
    I finished the transmission cooling system and shifter linkage. I'm running a B&M SuperCooler (70274), -8AN lines, and Performance Automatic cooler line adapters. For the shifter, I'm using a Performance Automatic AOD shift linkage (from my previous install) and a custom shift lever that I designed. It works great. The shift indicator lines up perfectly on the factory Cougar shifter. I should have the US Shift Quick 6 controller tomorrow and plan to be back on the road on Friday.
  15. #14
    Join Date
    Sep 2013
    Location
    ND USA
    Age
    56
    Posts
    2,029
    * leans back in my chair watching and reading in awe*
  16. #15
    Join Date
    Aug 2007
    Location
    Reno, Nevada
    Posts
    140
    Quote Originally Posted by ndtorque View Post
    Ha thank you!
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
    Bookmarks
    Posting Permissions
    • You may not post new threads
    • You may not post replies
    • You may not post attachments
    • You may not edit your posts
