School me on power steering on my 69 cougar
Results 1 to 6 of 6
Thread: School me on power steering on my 69 cougar
  1. #1
    So it is whining . It drives easy and turns great until I stop. Then its tight as all get out. Nothing you hadnt heard so far huh. Lol
    I added some fluid and its wanting to push itself out of the fill tube. Only filling it to the fill when hot line. I tried getting the tires off the ground and turn wheel trick. Didn't seem to help. A gentleman told me today I could bleed it at the steering box. Also what is the technical name for the power steering systrm on these cars ?
  2. #2
    Join Date
    May 2018
    Location
    New Hampshire
    Posts
    48
    Re: School me on power steering on my 69 cougar
    https://youtu.be/69idxXfXJv4
    That WCCC video should help
    Hidden Content
    First Cougar:
    1969 convertible
    351W 2bbl
  3. #3
    Join Date
    Mar 2002
    Location
    Dallas, Tx
    Age
    61
    Posts
    10,906
    Whining is caused usually by someone using the wrong fluid. You should only use Ford brand ATF in the system. Anything else will cause cavitation, ie foaming fluid. If allowed to continue long enough this moaning will ruin the pump. Your symptoms of low assist at parking lot speeds suggests that it is already ruined. You cannot install Dexron, Mercon, or anything that is called Power Steering Fluid. As the dipstick says, "Use only Ford ATF".
    The system in your Cougars was designed by Bendix in the early 1950's. It works well if the parts are in good shape and serviced with the proper fluid.
    Royce Peterson
    CCOA MEMBER #590
    1968 GT-E 427 XR-7 Augusta Green / Saddle It looks all stock Heh - Heh
    1968 XR-7 428CJ Ram Air Red / Black / Black C6
    1910 Model T Ford Touring Red/ / Black
    1914 Model T Ford touring Maroon / Black
    1915 Ford Model "T" Touring.....Black / Black (of course)
    1917 Ford Model T Roadster Green / Black
    XR7-G Registrar
    CURBSTER Hidden Content
  4. Remove Advertisements
    MercuryCougar.net
    Advertisements
  5. #4
    Ok so I replaced it with one from Summit. I had read to use only type F. Its working wonderfully as of right now. But now am I using the wrong fluid?
  6. #5
    Join Date
    Mar 2002
    Location
    Dallas, Tx
    Age
    61
    Posts
    10,906
    Type F is the correct fluid.
    Royce Peterson
    CCOA MEMBER #590
    XR7-G Registrar
  7. #6
    Join Date
    Feb 2011
    Location
    Pacifica, CA
    Posts
    4
    Quote Originally Posted by Mike from NH View Post
    Thank you so much for posting this video! The awful steering on my car has been driving me crazy! Now if I could just find a good Cougar mechanic in the San Francisco area...
Thread Information
Users Browsing this Thread
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
