Headlight relay kit installed
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Thread: Headlight relay kit installed
  1. #1
    Join Date
    Sep 2011
    Location
    California
    Posts
    67
    Hey guys, I thought I share another thing on here cause I know it may help alot of people on this site. I bought this headlight relay kit on ebay for $16 and its pretty cool since its plug and play and it truly made a huge difference on my car. Btw my headlamps are original.
    Click image for larger version.
    I took these pictures with the engine off since I didn't want to wake up the girlfriend
  2. #2
    Join Date
    Sep 2011
    Location
    California
    Posts
    67
  3. #3
    Join Date
    Mar 2002
    Location
    Dallas, Tx
    Age
    62
    Posts
    10,954
    Re: Headlight relay kit installed
    Looks interesting. The advertisement on eBay lacks any sort of detail about how many kits are needed or what tools are required to mount the system. Where did yu mount the relay? How much time was required? Is one kit enough for one Cougar?
    Royce Peterson
    CCOA MEMBER #590
    1968 GT-E 427 XR-7 Augusta Green / Saddle It looks all stock Heh - Heh
    1968 XR-7 428CJ Ram Air Red / Black / Black C6
    1910 Model T Ford Touring Red/ / Black
    1914 Model T Ford touring Maroon / Black
    1915 Ford Model "T" Touring.....Black / Black (of course)
    1917 Ford Model T Roadster Green / Black
    XR7-G Registrar
    CURBSTER Hidden Content
  4. #4
    Join Date
    Sep 2013
    Location
    ND USA
    Age
    56
    Posts
    2,049
    From the pictures of the connectors and relays it look pretty straight forward to 1) hooking up some power and grounds 2) plugging your headlight connectors into it 3) plugging it into your headlights .. nice find hard to buy just the connectors and relays for that price
  5. #5
    Join Date
    Sep 2011
    Location
    California
    Posts
    67
    Quote Originally Posted by Royce Peterson View Post
    Yes Royce, one kit if enough. The only two things I had to do is drill holes to mount the solenoid and and a small clamp to hold the wiring harness in place to keep it from getting crushed by the headlight door adjustment bolt. Yore right, not alot of info on this kit but seeing its made for older cars and in the past being able to install similar kits on my family's cars I was pretty confident it would work but if it didn't then I would modify it to make it work but thank fully it was just direct plug and play. Ill include some pictures
  6. #6
    Join Date
    Sep 2011
    Location
    California
    Posts
    67
    Yes its pretty straight forward. This is the best $16 bucks I ever spent. Here are some pics
    As you can see what bolt I use for my ground connections
    That rubber steel clamp I talked about earlier for holding my wiring harness in place to keep it away from getting crushed
    As you can see where I mounted my relays and ran the wiring behind the radiator for my driver side connections
    I like that you can't see the relays from here and as you can see this is where I wired my positive connection to the positive side of my solenoid starter
    And finally on the driver side this where I ran the wiring harness through and use the ground bolt. Very easy install and only took me about 2-3 hours.
  7. #7
    Join Date
    Sep 2013
    Location
    ND USA
    Age
    56
    Posts
    2,049
    Just as i thought .. nice clean setup .. I see from the ebay comments that the relays are on the cheap side but surly they can easily be upgraded.
  8. #8
    A few years ago, i got a headlight relay kit from Rocketman Bob. It was a great kit because it was made for a Cougar. Totally plug and play, and could be removed without having any altered wires.
    Hidden Content '68 XR-7 428 Cobra Jet (464ci.) w/toploader, Gear Vendors overdrive, 9" equa-lok Waterloo, Iowa
    Hidden Content
  9. #9
    Join Date
    Mar 2002
    Location
    Dallas, Tx
    Age
    62
    Posts
    10,954
    Thanks for all the helpful pictures!
    Royce Peterson
    CCOA MEMBER #590
    XR7-G Registrar
  10. #10
    Join Date
    Sep 2011
    Location
    California
    Posts
    67
    Quote Originally Posted by ndtorque View Post
    Thanks. Ive seen other similar kits with the same relays the have very positive reviews but for sure you could always upgrade
    Quote Originally Posted by Stangwires View Post
    Oh that one is nice and cost a pretty penny. For me, right now im trying to save a pretty penny lol especially with these gas prices
    Youre welcome Royce!
  11. #11
    Join Date
    May 2011
    Location
    Albuquerque NM
    Posts
    63
    This kit has two advantages: ceramic headlight sockets and improved separate ground wires.
    The ground wire upgrade is especially important for the 1969 Cougars because the original 14290 harness ground uses only 18ga wire.
    Vic Yarberry
    Cougars Unlimited LLC
    Hidden Content
    '67 Cougar 289 2x4V 4-speed
    '68 Cougar XR7 390 4-speed
    '70 Cougar 351C-4V 4-speed Convertible
  12. #12
    Join Date
    Oct 2013
    Location
    Torrance, California
    Age
    62
    Posts
    5
    Thanks for the info, photos and recommendation, alkhype! This looks like an easy but worthwhile project for my '69.
  13. #13
    I suggest buying your own high quality weatherproof relay and building your own harness to ensure you have quality parts and connections. I wouldn't trust this cheap Chinese eBay relay kit under my hood. Its not too complicated and could be done for only a few bucks more then this kit. Ive seen far too many of these cheap relays die, melt, corrode from moisture etc. The wiring is typically super cheap too and never holds up to the heat under the hood. The insulation will crack in a short time leaving the wiring exposed. On top of that the ring terminals are super thin material and bend out of shape easily and break off.
    Or spend the money for the rocketman kit.
  14. #14
    Join Date
    Oct 2018
    Location
    Missouri
    Posts
    19
    How much wiggle room do you have for mounting the relays? Does it have to be in the noseor could it be mounted on the fender well?
    1967 Cougar
    1969 Raider 12 Wheel horse
    1962 460 International Farmall
  15. #15
    Join Date
    Mar 2002
    Location
    Dallas, Tx
    Age
    62
    Posts
    10,954
    I think it would be less noticeable if they were mounted in the fenderwell outboard of the battery. Should be plenty of wire length.
    Royce Peterson
    CCOA MEMBER #590
    XR7-G Registrar
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
    Similar Threads
    1. New Edelbrock top end kit **FINALLY INSTALLED** but no power?
      By 1968Cougar in forum Classic Cougar Tech
      Last Post: November 12th, 2010, 12:27 PM
    2. help w/ rocketmans headlight relay kit
      By cammok5 in forum Classic Cougar Tech
      Last Post: July 15th, 2009, 01:28 PM
    3. Electric headlight door relay and connector
      By dennist in forum Classic Cougar Tech
      Last Post: November 15th, 2008, 02:54 PM
    4. installed new headlight switch now the HL doors wont close
      By Scali62 in forum Classic Cougar Tech
      Last Post: February 1st, 2006, 07:22 AM
    5. Headlight relay mod
      By kirkm76 in forum Cougar Community Discussion
      Last Post: February 26th, 2003, 02:14 PM
    Tags for this Thread
    Bookmarks
    Posting Permissions
    • You may not post new threads
    • You may not post replies
    • You may not post attachments
    • You may not edit your posts
