Secondary Fuse/relay box
Results 1 to 5 of 5
Thread: Secondary Fuse/relay box
  1. #1
    Join Date
    Oct 2018
    Location
    Missouri
    Posts
    19
    I am upgrading to a 3G alternator but would like to incorporate a new fuse/relay box in the mix. I was thinking mainly, headlights, fuel injection, fuel pump, Radio, maybe head light cover actuators as future projects. Does anyone had any pictures of their setup? I figure some one has something cleaner than a big box fastened to the wheel well like my pickup has. I have the parts but may get a head light relay setup before I start.
    Many Thanks
    Kevin
    1967 Cougar
    1969 Raider 12 Wheel horse
    1962 460 International Farmall
  2. #2
    Join Date
    Oct 2018
    Location
    Missouri
    Posts
    19
    Re: Secondary Fuse/relay box
    Well I test fit everything for the alternator upgrade. Had to shave a little off the ribs on the cover, no big deal. PAPerformance kit swapped out the regulator. Both the old alternator and regulator cheap stuff so good reddens. Still I go back and there is no room for the mega fuse or a secondary fusebox. Then it hits me, the battery would be more at home in my tractor. They cut the side out of the battery tray and the battery is extending 3 inches past the tray. Nothing is going to fit right with that monster in there. So I will pull the battery and mock up mounts for everything. Hopefully no surprises.
    Its never the upgrade its the things you find when doing the upgrade.
    1967 Cougar
  3. #3
    Join Date
    Oct 2018
    Location
    Missouri
    Posts
    19
    The headlight harness came in last night. I laid it out and it looks like everything should reach. So I am hoping that I can get it in this weekend after I finish the alternator. It is going to be raining so I should have the time. But there will be no test drive with BLU having a bad cowl.
    1967 Cougar
  4. Remove Advertisements
    MercuryCougar.net
    Advertisements
  5. #4
    Join Date
    Oct 2018
    Location
    Missouri
    Posts
    19
    Wrong it does not reach. I will have to get some wires replaced. Still a bargain at three times the price. I did finish the alternator up and is functions great. And we had a gully washer, great view from the garage.
    1967 Cougar
  6. #5
    Join Date
    Sep 2013
    Location
    ND USA
    Age
    55
    Posts
    2,006
    Wishing you and your Cougar the best .. Hope the nasty weather forecast for weather down there leaves your garage on it's foundation .
Thread Information
Users Browsing this Thread
    Similar Threads
    1. Replies: 6
      Last Post: September 21st, 2015, 07:34 PM
    2. Fuse box? Fuse Sizes?
      By big bad blue in forum Classic Cougar Tech
      Last Post: March 21st, 2010, 07:44 PM
    3. Replies: 1
      Last Post: May 11th, 2007, 04:23 PM
    4. Secondary locations of Vin# on a 1970 cougar.
      By rojoscar in forum Classic Cougar Tech
      Last Post: September 12th, 2005, 01:23 PM
    5. Holley 4160 secondary jetplate size.
      By Radioman in forum Classic Cougar Tech
      Last Post: May 22nd, 2004, 04:49 AM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
