Vacuum Diagram
Results 1 to 3 of 3
Thread: Vacuum Diagram
  1. #1
    Vacuum Diagram
    Hello all.
    I'm in need of a legible vacuum diagram (with an actual picture of the engine compartment if possible) for my 1977 XR-7 351W. the car is all original and a lot of it needs to be replaced with fresh rubber. I'm afraid that some of it isn't correctly routed because the vacuum advance wasn't connected to a ported vacuum. Thanks for your time. Derek
  2. #2
    Hi there. I'm in the same boat with a 77 xr7 with the 351m. I think I've puzzled it out by process of elimination. What I've seen is there seems to be a whole lot of BS about how much of q power killer vaccum is so everyone's afraid of it. Easiest way I found was to do each "circuit" (advance, egr, pv etc) separately, then add check valves and accesories, and lastly plug anything that remains open.. it's my understanding these motors were retrofitted with more than what was needed to make it easier to add later. Good luck and let me know how it turns out.
  3. #3
    Join Date
    Mar 2001
    Location
    Brisbane, Australia
    Age
    69
    Posts
    5,843
    Re: Vacuum Diagram
    The Thunderbird forums are another good source of information about 77 - 79 Cougars
    I found some diagrams on-line when I was working on my 77 wagon
    Leon
    Brisbane, Australia
    Hidden Content
    Designed to be driven
    Hidden Content
    Hidden Content
Thread Information
Users Browsing this Thread
There are currently 2 users browsing this thread. (0 members and 2 guests)
    Similar Threads
    1. Miata headlight diagram conversion diagram i made....
      By mn12xr7 in forum Classic Cougar Tech
      Last Post: December 1st, 2010, 08:57 AM
    2. Vacuum Diagram
      By cougar69 in forum Classic Cougar Tech
      Last Post: March 8th, 2003, 01:11 PM
    3. 70 XR7 Vacuum Diagram
      By 70BIGT in forum The Den
      Last Post: January 11th, 2003, 05:54 PM
    4. vacuum diagram
      By kirkm76 in forum Cougar Community Discussion
      Last Post: November 20th, 2002, 07:58 PM
    5. Ok, now how about a vacuum diagram?
      By bruter in forum Cougar Community Discussion
      Last Post: December 3rd, 2001, 01:11 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
