How to? Front Coil spring compression? - Page 3
Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 69
Thread: How to? Front Coil spring compression?
  1. #31
    Join Date
    Nov 2004
    Location
    NJ
    Age
    58
    Posts
    13,444
    Re: How to? Front Coil spring compression?
    Quote Originally Posted by bosselim69 View Post
    Yep, this is the best all around one to have in your tool box. http://www.ebay.com/itm/Coil-Spring-...#ht_1653wt_932
    Use a gear wrench on it and the process is quick, easy and safe. Pretty much the same design that is in the factory manual.
    The tool I like allows a impact wrench to be used to through the top (with the shock tower cap removed). I think this beats the heck out of cranking a gear wrench or whatever between the turns of the coil.
    Having said that, to each their own!
    Isabel: The realization of a seven year long dream:
    Hidden Content
    Hidden Content
    Canted--Texan on the351cforum: "One of my most impressive attributes is that.......a lot of people don't like me.....or the horse I rode in on"
  2. #32
    Join Date
    Nov 2004
    Location
    NJ
    Age
    58
    Posts
    13,444
    Quote Originally Posted by Cougar Bill View Post
    ...Tighten thru the shock hole (3/4" socket)...
    Now you're talking! IMO, this is the right way regardless of whether you elect to use the single set of hooks and fork type or the double set of hooks type.
    Hidden Content
    Hidden Content
  3. #33
    Join Date
    Mar 2003
    Location
    Marshall, MI
    Posts
    1,586
    Quote Originally Posted by 1969XR7Vert View Post
    You should "never" use an impact wrench on a spring compressor or gear puller. Turn it the opposite way and using a socket and ratchet thru the shock tower hole is OK. The only down fall is it is hard to fit the plate up high enough in the top of the spring to grab enough coils to compress it down for removal. It works for Mark with the short coil springs. fficeffice" />
    Brian Carpenter
    67 Cougar standard
    67 Cougar XR7
    68 XR7-G trailer queen restoration.
    68 Restomod
    69 Boss 302 Eliminator
    69 Cougar standard
    69 Cougar XR7 390 original
    69 Cougar XR7 428CJ 4spd
    70 Boss 302 Mustang
    1993 Harley Davidson
    2004 F250 diesel
    1999 Jeep Limited
    2004 Jeep Overland 4.7L H.O.
    "I could see the body, the tail and the head, the entire animal, perfectly. It's not a bobcat, it's not a housecat, it's a cougar.
    "It's a sleek animal. It ran low to the ground and stealth-like. It moved with elegance."
  4. Remove Advertisements
    MercuryCougar.net
    Advertisements
  5. #34
    Join Date
    Jun 2003
    Location
    Palmdale, CA
    Posts
    8,171
    In my experience this is the best way to use this tool. (fork at the top and turn from between cols) If you put the fork at the top there is a possibility of bottoming out the threaded shaft on the spring perch then you have to undo everything then reposition the tool and start over.
    Original tool had a ball on the end that engaged the fork at the bottom. Then the tool was turned from the shock hole at the top of the spring tower.
    "Don't blame me. I voted for Kodos"
    This is a SERIOUS addiction. There is no patch. There is no gum. You're stuck with this one.
    "I had the right to remain silent, but not the ability." - Ron White
    1969 XR 7 Coupe 351W, Meadowlark Yellow/Saddle
    2011 Fusion SE I4 6-speed auto with Appearance Package, Silver
    1981 Honda CB900F - Original owner
    2016 Fusion SE 2.5 - Green/Tan
    My other 1200 cars are 1/25 scale
  6. #35
    Join Date
    Sep 2009
    Location
    Upstate, NY
    Age
    53
    Posts
    2,055
    OK, more fuel for the fire. Besides expensive, what about this one?
    http://www.amazon.com/OTC-7045B-Fron...ef=pd_sim_hi_5
    1974 Dodge Dart - daily driver
    1968 XR7 F code - diamond blue/blue
    1968 XR7 J code - black/red
    1968 J code - madras blue/aqua
    1968 XR7 X code - lime frost/dark ivy gold
    1968 GT-E XR7 W code prototype no. 500033 - red/black
  7. #36
    Join Date
    Oct 2010
    Location
    Lapeer, Michigan
    Age
    54
    Posts
    1,818
    Well went to work today on installing the springs. Ended up going to Autozone and renting one of the ones in the red plastic box. Leaned a few lessons and it took me all day up till eight o:clock tonight to get one spring installed! My arm and shoulder are killing me. Using an open end wrench to boot. I tried to position the compressor so that I could turn it from the shock tower opening. No go. bolt would extend to far down into the spring seat. Ended up compressing and un compressing the spring five times before I got it right. Then found out there was to much friction to loosen it once I had it on the car. Off it came and I struggled to get the compressor back off. Then I greased the heck out of the bolt and the washers at the bolt head. One more time. Springs are seventeen and a half inches un compressed. Had to compress it down to eleven and a half to get it in. The last time with the help of a socket and extension on the fork to hold it I got it in place and released the compressor. If my arm is up to it I will do the other one tomorrow. should only take a couple hours or less this time. If I thought I would have to do this over I would invest in a tool that worked through the shock opening definitely!
  8. #37
    Join Date
    Oct 2010
    Location
    Lapeer, Michigan
    Age
    54
    Posts
    1,818
    Al that one is expensive. It looks safe and long enough to work through the top though. I like it.
  9. #38
    Join Date
    Sep 2013
    Location
    ND USA
    Age
    53
    Posts
    1,763
    http://www.amazon.com/Advanced-Tool-...m_cr_pr_sims_t
    these also work and you can install your shocks .....
  10. #39
    Join Date
    Nov 2004
    Location
    NJ
    Age
    58
    Posts
    13,444
    Quote Originally Posted by ndtorque View Post
    That type is dangerous IMO.
    Hidden Content
    Hidden Content
  11. #40
    Join Date
    Nov 2004
    Location
    NJ
    Age
    58
    Posts
    13,444
    Quote Originally Posted by Harvey View Post
    With the right tool, this is a 20 minute job.
    Hidden Content
    Hidden Content
  12. #41
    Join Date
    Mar 2003
    Location
    Marshall, MI
    Posts
    1,586
    As bob stated, it's a 20 minute job at best. Get a gear wrench and it speeds up the use of the tool. I'm sure you have now experience how hard it is to get a socket and ratchet in there. Using a box end wrench just takes way too long. I'll be removing the springs on a 67 Cougar project next week. Maybe it's time to make a short video of the process.fficeffice" />
    Brian Carpenter
    67 Cougar standard
    67 Cougar XR7
    68 Restomod
    69 Cougar standard
    70 Boss 302 Mustang
    2004 F250 diesel
    1999 Jeep Limited
  13. #42
    Join Date
    Aug 2011
    Location
    Chesapeake Va
    Age
    50
    Posts
    540
    I found that if you jack on the LCA just a little at a time, it makes turning the bolt much easier. Key word is "just a little at a time". I found that by keping the LCA supported, it seemed like there would be less of a liklihood of that thing flying out. I mean, thats almost what you have to do once you get a little compression on the spring. Once you get it compressed beyond the point where it is touching the seats, it get harder and harder to tighten/loosen the spring cmopressor. If you dont put tension on the LCA, you are fighting a battle keeping the spring in place when you are tightening/loosening the spring compressor.
    I agree..20 minute job..tops.
    Andy
    ____________________________________
    '68 STD
    '71 302 Block/'69 Heads
    Performer RPM
    600 cfm Holley
    '68 C4
    Hidden Content
  14. #43
    Join Date
    Feb 2001
    Location
    Golden, Colorado
    Posts
    1,052
    People have brought up a few points.
    "I tried to position the compressor so that I could turn it from the shock tower opening. No go. bolt would extend to far down into the spring seat."
    I did cut the end down a bit as I recall, so it did not hit the spring seat.
    "Springs are seventeen and a half inches un compressed. Had to compress it down to eleven and a half to get it in."
    What springs are these? The books I have show most springs at 14' to 15" " free height. I have used the MOOG 8356 with good results. 10.5 loaded 15.036 free height.
    No wonder your having a few issues w/ all this!
    Safety note: You should install hose clamps on the spring either side of the fingers. This will keep the finger from moving during compress/un-compress. MOST important when installing new springs- painted & slippery!
    Again hope this helps!
    Cougar Bill
    1970 XR-7 Q code 4 speed Ram Air- Now on rotiserie
    1969 XR-7 R code 4 speed Blue/ Blue 4 speed
    1969 Std R-code auto Blue/Black
    1969 XR-7 RestoMod 351W-4v T5 Rebuilt at 525 crank HP
    Hidden Content
    1969 XR-7 Convertible 351W-4v AOD
    1969 XR-7 Convertible 428 Q C6 (401K plan)
    1967 XR-7 289 4V C4 Wifes Cat - New 302 & AOD w/ 9"
    1968 Std 390 auto ( future track cat)
    2002 F250 XLT SuperDuty 7.3 Diesel
    25' lowboy trailer
    28" enclosed trailer
    Golden, Colorado
    Restoring Cougars is my love & my business!
  15. #44
    Join Date
    Dec 2004
    Location
    Salem Oregon
    Posts
    6,450
    This style is the only one you should use in my opinion. We will have a like compressor on our site that you can borrow for free when you buy front end components from us, we will also have them for sale next week. Watch this video to see how easy and safe they are to use.
  16. #45
    Join Date
    Oct 2010
    Location
    Lapeer, Michigan
    Age
    54
    Posts
    1,818
    A day late Don. I got the second spring on today. Still took me a while. About an hour using an open end wrench to turn the compressor....Boy is my should sore! The springs are original from a 68 XR7 with 390 and air conditioning. I didn't want the compressor forks to move or scratch the springs. I had an old piece of fire hose witch is canvas on the outside and rubber on the inside that I put between the fork and hooks and the spring. This worked out very well and it never walked around on me. Can't imagine doing one of these in 20 minutes without power tools!
Thread Information
Users Browsing this Thread
    Similar Threads
    1. Front coil spring spacer question
      By Stangwires in forum Classic Cougar Tech
      Last Post: June 22nd, 2010, 08:24 AM
    2. Front Coil Spring question
      By jimk127 in forum Classic Cougar Tech
      Last Post: January 27th, 2009, 07:14 PM
    3. stripe on front coil spring?
      By DeMaxx1 in forum Classic Cougar Tech
      Last Post: May 13th, 2006, 03:52 PM
    4. Coil spring compression tool? general question
      By AZCAT in forum Classic Cougar Tech
      Last Post: September 6th, 2005, 01:25 PM
    5. Front Coil Spring Question
      By bclay1818 in forum Cougar Community Discussion
      Last Post: January 28th, 2003, 11:01 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
