Does any one know of a good supplier for all the seals/gaskets on the heater system? I need the round fresh air vents gaskets. and defroster to heater box seal and everything else involved in taking the heater box out.
been there done that. of course I had to do it twice. got the core working. then got the defroster plenum. Thought I could put it on without removing the core again. WRONG! :ylsup:
On thing about most seal kits, they have all the seal needed except for the ones that attach to the heater core. Try not to damage those when you remove the core. I think someone finally sells those, although I haven't looked for any in a while.
I get mine from Virginia Mustang. Lots cheaper $8.95 !! Use 3M caulking rope to seal the box halves (69/70 are this way) As Bruce mentioned, the core seals (top & bottom) are NOT included. I use rubber cement to glue them back in place. Take your time, repair any damage with fiberglass and you'll have years of "heat". Just be carefull reinstalling the box. The heater core tube are very fragile and can crack. leading to the old saying, " It ain't done right till ya done it 3 times!!
Good Luck!
Related Threads
Mercury Cougar Owners
586.3K posts
20.8K members
Since 2001
