Trick Flow heads
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Thread: Trick Flow heads
  1. #1
    Join Date
    Dec 2004
    Location
    Denver, Co. USPS VMF
    Age
    51
    Posts
    7,466
    Trick Flow heads
    I bought a pair of trick flow heads back in 05, while I was deployed, and in Germany.
    These last few weeks, I have been getting my poop all in one sock, so that I can finish the build of my 69 Cougar.
    The pair of heads that I bought had one bad valve in one of the heads, from the factory.
    The only reason I know this, is that the guy who did the rest of the machine work on my block told me about the problem.
    Today, I tried to bolt these same heads onto my block, using head studs, instead of the stock head bolts, and I found that they didn't fit.
    It seems that the pair of heads I bought also have about a 1/32nd of material that prevents them from fitting on the half inch head bolts that come stock on a W.
    Did I get a bad pair, or is this pretty common? I know that they sell a 'bushing' to fit all heads on both the 289/302 and 351W block. It seems to me that the heads should have slid straight onto the head studs with no interference. As it is, I will have to either spend some time with a round file, or take them back to teh machine shop for a quick hole enlargement.
    is this a common problem for new, aluminum heads? I mean they are 5 years old, but still straight out of the box....What do you think?
    67 XR7, 68 5 SP, 69 5 speed build in progress Hidden Content Hidden Content
    *Disclaimer!! All info provided by the woodsnake is free, and worth what it costs!! Use with caution*
    What can I say, I like Cougars...
    " yer darn right wow "
    All my projects, pictures and audio clips.
    Hidden Content
    "Time to let the Cougar loose" R.B.
  2. #2
    Join Date
    Sep 2012
    Location
    Russellville, KY
    Posts
    61
    Re: Trick Flow heads
    The 289/302 uses a 7/16 head bolt while the 351-W uses a 1/2 head bolt. Trick Flow machines, or says they do, all their heads at 1/2 and you need to use a bushing if you plan to use them on a 289/302. If I were you I would contact Trick Flow and explain the situation, who knows they may help you even if the heads are 7 yrs old. At the worst you will be where you are right now.
    David
  3. #3
    Join Date
    May 2008
    Location
    Cedar Rapids, Iowa
    Age
    52
    Posts
    11,925
    HUH? They should have been just fine on your W though? The only difference is the size not the location as far as I know.....it sounds like something is off or a bent stud perhaps? If you have to do something I would have a machine shop do it. A call to to TF sounds like the best first move though.
    1969 E-cat warmed-over 351W AOD
    1969 XR7 S Code vert in progress
    1968 F code XR7 - waiting for re-imbursment from bro-in law :>\
    1998 F150 4x4 D.D - 300k on the clock!
    2001 F150 4x4 backup for 98 ;>P
    2 x 1985 Suzuki Madura 1200's. One done - one in progress
  4. Remove Advertisements
    MercuryCougar.net
    Advertisements
  5. #4
    Join Date
    Dec 2004
    Location
    Age
    51
    Posts
    7,466
    It took another four hours out of my day yesterday, plus another 43 dollars, to get the holes "finish" drilled.
    I just got a bad pair of heads, from the factory. But, the new valve is in, and the heads are
    on the car.
    After I drop off the car this week, I will send TF the bad valve and a nastily worded three page letter, explaining why their product sucks.
    Hidden Content
  6. #5
    Join Date
    May 2008
    Location
    Cedar Rapids, Iowa
    Age
    52
    Posts
    11,925
    AMEN to that! Not what I would have expected from them.....send them a copy of the bill too
  7. #6
    Join Date
    Dec 2004
    Location
    Age
    51
    Posts
    7,466
    Click image for larger version.
Name:	All my projects 1645.jpg
ID:	31622Click image for larger version.
Name:	All my projects 1656.jpg
ID:	31623Click image for larger version.
Name:	All my projects 1658.jpg
ID:	31624Click image for larger version.
Name:	All my projects 1666.jpg
ID:	31625So, here are some shots from the assembly...
    Crank and bock from machine shop, two piece eccentric, and holes for roller cam assembly, as well as my VIN stamped into the block.
    Hidden Content
  8. #7
    Join Date
    May 2008
    Location
    Cedar Rapids, Iowa
    Age
    52
    Posts
    11,925
    Make sure to mount the crank - even if it's loosely for storage until you have to time to install it and never stand them on end. They distort pretty quickly in a short period of time without support. Looking good!!
  9. #8
    Join Date
    Dec 2004
    Location
    Age
    51
    Posts
    7,466
Name:	All my projects 1671.jpg
ID:	31630Click image for larger version.
Name:	All my projects 1675.jpg
ID:	31631Click image for larger version.
Name:	All my projects 1678.jpg
ID:	31632Here is a shot of the master cylinder for the hydraulic clutch. Marking out the location was at least as hard as reaching in to drill the hole. WHAT A PITA!! Glad it was only once. The next is a shot of the assembled spider and dog bones for the retro roller cam. And of course, the married engine and transmission, waiting to go into the car. As things stand, the engine and trans are installed, sitting in the car, sitting in a storage unit in Colorado. I had to get a different trans cross member, as the one I bought on Ebay in fact did not fit as described. So I bought the tubular piece. I still have to measure for pushrods, as the ones that came in the cam kit are supposed to be now too short. So I will measure, and confirm the length that I need. I also don't have the studs for the rocker arms, as they somehow got packed away, with the rest of the house. Bummer, that.....
    I am still in Disney, FLA, until probably the first of the year, when I head back to Colorado, to look for a real JOB..
    I just wanted to take a minute in between things here and post some pictures....
    Hidden Content
  10. #9
    Join Date
    Dec 2004
    Location
    Age
    51
    Posts
    7,466
    Crank, rods and pistons are all safe in their new home, just the valve train needs finished..
    Hidden Content
  11. #10
    Join Date
    Sep 2009
    Location
    Upstate, NY
    Age
    53
    Posts
    2,055
    Quote Originally Posted by Bad69cat View Post
    I always heard you were supposed to store a crank standing on end. Not true?
    1974 Dodge Dart - daily driver
    1968 XR7 F code - diamond blue/blue
    1968 XR7 J code - black/red
    1968 J code - madras blue/aqua
    1968 XR7 X code - lime frost/dark ivy gold
    1968 GT-E XR7 W code prototype no. 500033 - red/black
  12. #11
    Join Date
    Feb 2001
    Location
    Grafton, Ohio
    Age
    58
    Posts
    5,470
    Lookin' good, Wood!
    You're gonna love the retrofit roller cam! No worries!
  13. #12
    Join Date
    Dec 2004
    Location
    Age
    51
    Posts
    7,466
    I hope so..I agonized over how much cam to buy, especially after I found out I bought the "wrong" heads....But I think, even with only the 170 TF heads, the 3.89 rear end gear will work nicely with the .513 lift....I just want to hurry up and get home so I can finish the assembly.
    Hidden Content
  14. #13
    Join Date
    Dec 2004
    Location
    Age
    51
    Posts
    7,466
Name:	All my projects 1669.jpg
ID:	31633Click image for larger version.
Name:	All my projects 1668.jpg
    Another couple of views of the installed master cylinder. I'm thinking this is MUCH easier, with the engine out of the way. But it might not be all that bad, either, if you have a small child, or tweenage girl around, with small hands....
    Hidden Content
  15. #14
    Join Date
    May 2008
    Location
    Cedar Rapids, Iowa
    Age
    52
    Posts
    11,925
    Quote Originally Posted by Al Bundy View Post
    No - they need support on the main journals - since the weight of the counter weights will follow gravity....it's best to build a support of some kind for long term storage.
  16. #15
    Join Date
    Dec 2004
    Location
    Age
    51
    Posts
    7,466
    Here is the reply from Trick Flow.
    "We have a 90 day warranty against workmanship and machining on the heads. Being you purchased them 7 years ago there is nothing I can do for you. The heads do not come drilled for 1/2" bolts. Yes they are half way drilled for them just in the case you are running them on a 351 where it requires the 1/2" bolt, but the heads are drilled for the 7/16" bolt that the more common 302 uses. It is stated in the description of the heads that they are drilled for 7/16" bolts."
    So there you have it. Nothing on the valve either. So, mark against TF heads....
    Hidden Content
Thread Information
Users Browsing this Thread
    Similar Threads
    1. My new trick flow heads
      By Ron67 in forum High Performance
      Last Post: February 9th, 2010, 09:18 PM
    2. Trick Flow iron heads
      By RoadRacer68 in forum Misc. Parts for Sale
      Last Post: December 7th, 2009, 09:52 PM
    3. trick flow heads with titanium valves
      By M Early in forum Misc. Parts for Sale
      Last Post: November 10th, 2009, 10:20 PM
    4. 351C Trick flow heads
      By fast70cougar in forum High Performance
      Last Post: May 12th, 2009, 02:45 PM
    5. trick flow
      By 69Hcode in forum Classic Cougar Tech
      Last Post: January 9th, 2004, 07:56 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
