Boiling Battery
+ Reply to Thread
Results 1 to 14 of 14
Thread: Boiling Battery
  1. #1
    Join Date
    Feb 2012
    Location
    Indianapolis
    Age
    31
    Posts
    91
    Boiling Battery
    Today while driving around, my batter started boiling.... I'm lead to believe this is the alternator overcharging. Also, it could be a bad voltage regulator. What's the best way to go about fixing this? Any advice is greatly appreciated.
    '67 Mercury Cougar XR-7
    '11 Toyota Prius
    '12 Toyota Tacoma
    My old '68 that I foolishly wrecked turning donuts R.I.P.
  2. #2
    Join Date
    Apr 2012
    Location
    Vermont
    Posts
    114
    Re: Boiling Battery
    Test the alternator by touching the positive multi-meter probe to the positive terminal on your battery and likewise the negative probe to the negative terminal on your battery. If the alternator is working, your multi-meter should read somewhere in the vicinity of 14 volts (typically 13.8v-14.2v). If it is reading excessively higher than 14 volts (greater than 15 volts) it is most likely that the voltage regulator is faulty or going bad.
    1969 XR-7 (Eliminator clone), 351W, Auto
    2006 F10SC 4X4 XLT
    2006 VTX 1800s spec 3
  3. #3
    Join Date
    May 2010
    Location
    Nampa, ID
    Age
    30
    Posts
    317
    Re: Boiling Battery
    A couple weeks ago, my battery boiled over, but that was because I had filled it too full and when current started to move it had no where for the water (now acid) to boil...so it boiled over a little bit...
    --- Chad ---
    1968 Cougar "Nala"
    2003 Mustang "Snowflake"
    2012 Ram 2500 "Beast"
  4. #4
    Join Date
    Feb 2012
    Location
    Indianapolis
    Age
    31
    Posts
    91
    Re: Boiling Battery
    Where can I find the voltage regulator on a 67?
    '11 Toyota Prius
    '12 Toyota Tacoma
  5. #5
    Join Date
    Apr 2012
    Location
    Vermont
    Posts
    114
    Re: Boiling Battery
    I am not 100% sure but I believe it's either mounted beside the radiator support or on the drivers side inner fender beside the solenoid. It looks like this.... or close to it... http://www.drivewire.com/includes/se...Qgd2FycmFudHku
    2006 F10SC 4X4 XLT
  6. #6
    Join Date
    Feb 2012
    Location
    Indianapolis
    Age
    31
    Posts
    91
    Re: Boiling Battery
    Thanks! As a precaution, should I change out the battery too?
    '11 Toyota Prius
    '12 Toyota Tacoma
  7. #7
    Join Date
    Apr 2012
    Location
    Vermont
    Posts
    114
    Re: Boiling Battery
    If it were me I would charge the battery fully and load test it If you don't own a battery tester, take it to a parts store and have it load tested, It will rule out a shorted cell or weak battery.
    2006 F10SC 4X4 XLT
  8. #8
    Join Date
    Feb 2012
    Location
    Indianapolis
    Age
    31
    Posts
    91
    Re: Boiling Battery
    Do you think the voltage regulator they sell at Autozone is solid state or mechanical?
    '11 Toyota Prius
    '12 Toyota Tacoma
  9. #9
    Join Date
    Apr 2012
    Location
    Vermont
    Posts
    114
    Re: Boiling Battery
    Call them and ask....
    2006 F10SC 4X4 XLT
  10. #10
    Join Date
    May 2008
    Location
    Cedar Rapids, Iowa
    Age
    48
    Posts
    7,160
    Re: Boiling Battery
    Most likely solid state now - and they are known to be problematic if they are made in China....try to get a USA made one. These guyscan rebuild it or sell you a good one, or tell you how to convert it to a 1G type using your existing alt....http://www.qualitypowerauto.com/pages/AboutUs.php
    ^^Dirty, Filthy, Rich.....2 out out of 3 ain't bad!
  11. #11
    Join Date
    Feb 2012
    Location
    Indianapolis
    Age
    31
    Posts
    91
    Re: Boiling Battery
    Okay, I changed out the voltage regulator and the battery. The old regulator was clearing 15 volts when I put the multimeter on it. The new one is giving me readings around 14.6 volts. Is this within tolerated levels, or am I going to have to dive it around and see if my new batter boils?
    '11 Toyota Prius
    '12 Toyota Tacoma
  12. #12
    Join Date
    Apr 2012
    Location
    Vermont
    Posts
    114
    Re: Boiling Battery
    Did you throughly clean the battery terminals before installing thr new battery... both on the battery and cable ends? I would put a charger on 2amps and slow charge the new battery first then test it. 14.6v the max I would like to see going to the battery. Check it with the vehicle running no accessories on then with lights and heater.... then let us know the readings.
    2006 F10SC 4X4 XLT
  13. #13
    Join Date
    Feb 2012
    Location
    Indianapolis
    Age
    31
    Posts
    91
    Re: Boiling Battery
    I drove my Cougar around a good bit today, and after I finished, I tested the battery. It's holding steady at about 12.7 volts (car not running), so I don't think it's over charging any more. I think the new regulator was what I needed. Also, I opened up the old regulator and saw one of the wires was burnt up, so it's really no surprise it needed a new one. Thanks for all the great advice guys!
    '11 Toyota Prius
    '12 Toyota Tacoma
  14. #14
    Join Date
    May 2008
    Location
    Cedar Rapids, Iowa
    Age
    48
    Posts
    7,160
    Re: Boiling Battery
    Keep an eye on it for awhile but it sounds like you got it fixed.
+ Reply to Thread
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Threads
  1. '68 302 Radiator Boiling
    By TracyM in forum Classic Cougar Tech
    Last Post: September 6th, 2008, 06:29 PM
  2. boiling over
    By GFUJI in forum Classic Cougar Tech
    Last Post: September 6th, 2008, 08:33 AM
  3. Boiling Battery?
    By 68 MERC in forum The Den
    Last Post: September 2nd, 2007, 02:40 PM
  4. Boiling Gas I think
    By Zogman in forum Classic Cougar Tech
    Last Post: May 12th, 2007, 08:47 AM
  5. Fuel boiling in bowl
    By 302fix in forum Classic Cougar Tech
    Last Post: August 3rd, 2005, 07:47 PM
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
