backspace question
Results 1 to 6 of 6
Thread: backspace question
  1. #1
    Join Date
    Apr 2007
    Location
    Colorado Springs, CO
    Age
    35
    Posts
    291
    backspace question
    What is the minimum backspace that will fit a 68 Cougar 15 inch rims.
    Thanks
    Evil Prevails when good men fail to act....
    Kick the tires and light the fires big daddy...
    CHUCK
    1968 MERCURY COUGAR (STD) Building
    2002 FORD CONVERSION VAN
    1972 FORD RANCHERO
  2. #2
    Join Date
    Mar 2011
    Location
    White Salmon, WA
    Posts
    10
    Re: backspace question
    If I remember correctly about 3.5" it all depends on tire size and rim width though. On a 15x8 you will likely want around 4.25. The best way I know and what I used to do when doing custom wheels even in 17" is to measure the fit of the tire/wheel package. To do this know the width of the tire you want to run. Let say 235 for arguments sake. 235/25.4 is 9.25" tread width. So take a tire off, put a straight edge against the axle hub/drum extending it up into the wheel well and start your measurement from the back of that edge. get that 9.25 where you have lip clearance at the quarter panel. Factor in the width of tread you want and leave enough wheel well and lip clearance (at least 1"). Measure twice as always, write it down and check again.
    I used to do this on all sorts of hot rods etc and always had great fit. You can easily get a 255 in there and likely 265/50/15. If you need more info I can pull my 68 apart and measure it. I have 18x9.5 on the rear (not by choice, leftovers from wifes 04 stang).
  3. #3
    Join Date
    Apr 2007
    Location
    Age
    35
    Posts
    291
    Quote Originally Posted by Talon258 View Post
    Thank you this truly helps. I will keep ya posted
    CHUCK
    1972 FORD RANCHERO
  4. Remove Advertisements
    MercuryCougar.net
    Advertisements
  5. #4
    Join Date
    Dec 2002
    Location
    Chesterland, Ohio
    Age
    50
    Posts
    6,131
    Backspace ultimately depends on how wide the wheel and tire is. The narrower the rim, the less backspace you can get away with.
    You would ideally want the mounting flange of the wheel to be centered in the wheel with respect to dish and backspace. More backspace = less dish which also affects "looks" just as much as overall fitment.
    So basically you need to decide how wide the 15" rim is going to be. Then backspace can be calculated to get it to fit centered in the wheelwell.
    Hidden Content
    Mark
    '68 XR-7 351W C6 3:50 1 of 1
    Anyone can restore a Classic, but it takes a Real Man to cut one up!
    Buckeye Boys Rod & Custom - East
    Reserved parking at the Hidden Content .
    First Official "Ride Of The Month" at Hidden Content
    Illegally parked on the Hidden Content
  6. #5
    Join Date
    Apr 2007
    Location
    Age
    35
    Posts
    291
    Thinking of 15x10 will it fit the 68 Cougar without modifying anything?
    CHUCK
    1972 FORD RANCHERO
  7. #6
    Join Date
    May 2008
    Location
    Cedar Rapids, Iowa
    Age
    52
    Posts
    11,931
    I wish somebody would buy that Percy wheel fitment tool from summit/jegs and loan it to everyone who needs this info.... Wink., wink, nudge, nudge... I may need it soon
    1969 E-cat warmed-over 351W AOD
    1969 XR7 S Code vert in progress
    1968 F code XR7 - waiting for re-imbursment from bro-in law :>\
    1998 F150 4x4 D.D - 300k on the clock!
    2001 F150 4x4 backup for 98 ;>P
    2 x 1985 Suzuki Madura 1200's. One done - one in progress
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
    Similar Threads
    1. 351W idle speed question and vent question
      By maxgig in forum Classic Cougar Tech
      Last Post: January 3rd, 2011, 11:38 PM
    2. A '67 wiper question & alternator question
      By tacdab in forum Classic Cougar Tech
      Last Post: September 25th, 2004, 03:42 PM
    3. 1-2-3 question and eliminator question
      By 72 XR7 in forum Cougar Community Discussion
      Last Post: June 10th, 2004, 03:04 PM
    Bookmarks
    Posting Permissions
    • You may not post new threads
    • You may not post replies
    • You may not post attachments
    • You may not edit your posts
