New Brake Shoes for '68 Cougar
Results 1 to 7 of 7
Thread: New Brake Shoes for '68 Cougar
  1. #1
    Join Date
    Sep 2003
    Location
    Aiea, Hawaii
    Age
    71
    Posts
    74
    Angry New Brake Shoes for '68 Cougar
    I replaced the rear brake shoes with new ones from National Parts Depot. Adjusted shoes so the drums rotate with slight touching of lining. Checked brake pedal and all looks well. Re-install the wheels and attempt to back out of the garage. The car will not move. Thought maybe I forgot to remove the wheel blocks, but no everything is clear. So why will the car not move? Pull out the jack stands and get it in the air again. The rear wheels are locked solid.
    After dis-assembly and some head scratching, it appears the shoes are about 1/16 inch wider than the old shoes I removed. When the wheel is tightened to the axle, the shoes are clamped tight between the brake drum and backing plate, locking everything up. Everything about the shoes is correct except for the width of the metal shoe. Even the new lining matches the width of the old shoes, but the new metal shoe is slightly wider than the new lining. May be a Chinese metric conversion issue. Put the old shoes back on so the car is driveable, but it still needs new brake shoes.
    Anyone else ever experience this problem? The only solution I see is the bench grinder, or postage for return.
    1968 Std X-code/C6/Black Cherry/Black
    former:
    1968 XR7 J-code/C4/Black Cherry/Dark Red
    1963 Fairlane 260/3sp/Bronze/Bronze
    1969 Torino R-code/4sp/Indian Fire/Black
    1942 Ford 1/2 ton pickup, 239/3sp/Black/Tan
    1964 Galaxie P-code/4sp/Blue/Black
    1957 Fairlane 312/3spOD/Red&white/Black
    1950 Mercury 255/3spOD/Burgandy/Grey
    1948 Ford 239(later 255)3sp/Blue/Tan
    1941 Ford 239/3sp/Blue/Tan
    "Large increases in cost, with questionable increases in performance, can only be tolerated with fast cars and fast women." Lord Kelvin (updated)
  2. #2
    Join Date
    May 2001
    Location
    East Meadow,ny
    Age
    42
    Posts
    206
    Maybe they sent you front shoes instead of rear?
    If it ain't broke take it apart to see how it works
    '68 hardtop 302 2v p/s pbd onr of 400 with polar white exterior blue interior combo (2b)
  3. #3
    Join Date
    Jan 2010
    Location
    San Ramon ca
    Age
    50
    Posts
    379
    I went to disc on the rear, it was fast , easy , and cheap , and my 68 stops at least 3 times better than with drum .
  4. #4
    Join Date
    Jul 2010
    Location
    Rouyn-Noranda, Quebec
    Age
    61
    Posts
    1,267
    Quote Originally Posted by PBCOUG View Post
    does this involve work only on the rear, or does the switch require work under the hood?
    johnboy
    68 XR7 J code parked at Hidden Content
    Proud Member of the Hidden Content
  5. #5
    Join Date
    Nov 2004
    Location
    Rocky Mountain High Colorado
    Age
    60
    Posts
    2,717
    I had a CJ7 rear brakes bind up on me and lock. It seems the emergency brake cable(s) were defective. Make sure you've installed the emergency brake mechanisms correctly and are not engaging the rear brakes.
    What is the actual width of the shoe, maybe a few people can measure working brakes to compare. I would also give NPD a call and see what they have to say.
    1967 XR7 * Polar White * Saddle Tan * PS * PB * AC * AOD
    .....................Everyone is entitled to my opinion.
    Hidden Content
  6. #6
    Join Date
    May 2007
    Location
    Gresham, OR
    Age
    50
    Posts
    1,236
    Search the site. IIRC this has been posted about quite a bit in the past. I think secret agent Nancy had the problem on her cat when she was working on it.
    James
    Hidden Content
    Rule #8 "If it's stupid but works, it ain't stupid"
    1970 M-code Eliminator /R
    2004 Acura TL
    1999 Silverado LT
  7. #7
    Join Date
    Sep 2002
    Location
    Tuttle,OK
    Posts
    52
    Brakes
    After dealing with my brakes extensively the last couple of weeks (all new system) there are 2 sizes for the rear brake linings. 2 inch and 2 1/2 in. You probably need a 2" Wagner Part number PEB152. I use the PEB152R which the "R' is for riveted. About $30
    Hidden Content Hidden Content Glenn Gardiner
    Tuttle,OK
    69 XR7
    69 StandardHidden Content
Thread Information
Users Browsing this Thread
    Similar Threads
    1. 67 Cougar - Replacing brake lines
      By john_becker in forum Classic Cougar Tech
      Last Post: June 23rd, 2010, 12:26 PM
    2. cougar guroo brake question
      By graeserhp in forum Classic Cougar Tech
      Last Post: June 29th, 2009, 11:16 AM
    3. Need Cougar Interior Photos to be used in upcoming Cougar Catalog
      By Anthony Coles in forum Cougar Community Discussion
      Last Post: May 27th, 2009, 05:30 PM
    4. 1969 and 1970 cougar parts for sale and more
      By JUSSMPLCOUGARS in forum 69-70 Parts for Sale
      Last Post: October 2nd, 2008, 07:05 AM
    5. 1971 and a 1973 cougar full of parts for sale and more
      By JUSSMPLCOUGARS in forum 71 & Up Parts for Sale
      Last Post: September 4th, 2008, 06:24 AM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
