Spare Tire Lock
Results 1 to 4 of 4
Thread: Spare Tire Lock
  1. #1
    Spare Tire Lock
    I have a 73 XR-7 that has the spare tire lock. I have a new trunk mat to replace the torn one, and when I unlocked the spare tire to remove it, the lock wont come off. The key does unlock it, where it just spins. I have tried pulling up on it as I turned it, to no avail.
    I have even "gently" tapped it with a dead blow, in case something is sticking.
    I do not want to cut it off, and ideas?
  2. #2
    Join Date
    Dec 2005
    Location
    Lubbock, Tx
    Posts
    1,116
    try lubing the mechanism and the lock cylinder with some graphite lock cylinder lube. if you do end up having to cut it off i have a replacement i would sell you, it's a good used piece from a 70's lincoln, same as what was used on the cougar, torino etc.
  3. #3
    Join Date
    Jun 2008
    Location
    Crystal Lake,IL U.S.A.
    Posts
    527
    I'd try WD-40 first or a spray lube.
    Next, regardless of WD-40 residue.... Heat it up
    Last resort, cut it off
    current project....
    69 XR7 351w4v, FMX
  4. #4
    Thanks
    Thanks for the response, have sprayed it, still not wanting to let go, yet. Am letting it sit till next weekend and I will try to tap it into submission. If I do end up cutting it I don't think I will put another one on.
    Thanks again
Thread Information
Users Browsing this Thread
    Similar Threads
    1. Spare wheel and tire
      By Bad Kitty in forum Classic Cougar Tech
      Last Post: September 14th, 2008, 09:42 PM
    2. Original spare tire for 1969, what would it be
      By JUSSMPLCOUGARS in forum Cougar Community Discussion
      Last Post: August 4th, 2008, 10:24 PM
    3. Spare tire holder washer
      By Sensei69 in forum Parts Wanted
      Last Post: April 26th, 2008, 06:28 AM
    4. Spare tire questions....
      By jsv in forum Cougar Community Discussion
      Last Post: November 3rd, 2006, 10:54 AM
    5. Any need for a spare tire
      By neil in forum 71 & Up Parts for Sale
      Last Post: October 13th, 2005, 10:18 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
