Steering Wheel Replacement
Results 1 to 11 of 11
Thread: Steering Wheel Replacement
  1. #1
    Join Date
    Jun 2008
    Location
    Baytown, TX
    Age
    67
    Posts
    139
    What advice can anyone give me in reference to replacing the steering wheel on my non-power sterring 67 base model? My wheel is VERY cracked and broken. The horn pads cleaned up pretty good but not great. The Cougar emblem is okay except for one small crack. Is there a steering wheel anyone has used that is a good replacement for the stock wheel that won't break the bank to buy? No wood rimmed $500 units. Just a good replacement whell in the $100-$150 range or less, if possible. It wouold be nice if there was a wheel that you could attach the Cougar emblem to that would look right. Any ideas?
  2. #2
    Join Date
    Aug 2004
    Location
    Siloam Springs, Arkansas
    Age
    53
    Posts
    1,861
    I like the '70s vintage Ford "Sport" steering wheels, myself. They used to be a fairly common salvage yard part, (and you might still get lucky) but are more of a swap meet/ebay item these days.
    A quick ebay search turned one up: Item number 110276534587. There are probably others. They look at home in a vintage car, the center emblem can be changed with a little creativity, and they aren't flimsy like some aftermarket wheels.
    From the auction:
    (I know nothing about this seller. Usual disclaimers apply.)
    I haven't tried one on a '67, but they fit every other late 60s, early 70s Ford I've tried one on.
    Beware of wheels from '79 up Mustangs and Capris. They look the same, but don't have the rings on the back for the horn contacts like the ones from Mustang IIs, Pintos, Mavericks and Torinos.
    In fact, I'd ask the seller for the one above for a picture of the back side of the wheel to just be 100% sure its the right style, if I was seriously considering buying it.
    Good luck!
    No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
  3. #3
    Here's a Grant on ebay with buy it now. http://cgi.ebay.com/ebaymotors/Mercu...mZ130243774999
    catman
  4. Remove Advertisements
    MercuryCougar.net
    Advertisements
  5. #4
    Join Date
    Jun 2003
    Location
    Salem, Oregon
    Posts
    6,975
    Question
    Quote Originally Posted by cj750 View Post
    From the auction:
    Good luck!
    I have this exact same wheel, been saving it to put onto my 1968 XR7.
    What does the back need to look like?
    Hidden Content Hidden Content Hidden Content
    1968 XR7 J code 5 speed
    1968 Mustang GT/CS 302-4V
    "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming-----WOW---Whata ride!!!"
  6. #5
    Join Date
    Dec 2004
    Location
    Salem Oregon
    Posts
    6,445
    Quote Originally Posted by CougarCJ View Post
    It needs to look basically like the wheel you have now with two copper rings to contact the two copper spring loaded studs protruding from your turn signal switch.
  7. #6
    Join Date
    Jun 2003
    Location
    Palmdale, CA
    Posts
    8,164
    I tried using one of those Sport wheels on my 69 XR 7 but it didn't work. The bushing in the center with the splines would not allow the wheel to go on the shaft far enough to allow the horn contacts to touch the slip rings. I was able to make one work in my 72 Montego though.
    I hava a couple at home. If you want to buy and try one you are welcome to it.
    "Don't blame me. I voted for Kodos"
    This is a SERIOUS addiction. There is no patch. There is no gum. You're stuck with this one.
    "I had the right to remain silent, but not the ability." - Ron White
    1969 XR 7 Coupe 351W, Meadowlark Yellow/Saddle
    2011 Fusion SE I4 6-speed auto with Appearance Package, Silver
    1981 Honda CB900F - Original owner
    2016 Fusion SE 2.5 - Green/Tan
    My other 1200 cars are 1/25 scale
  8. #7
    Join Date
    Aug 2004
    Location
    Age
    53
    Posts
    1,861
    Basically just like your stock wheel. Two metallic rings, insulated from each other. Here's what the wrong one looks like:
    And here's the one that works:
    As you can see, its hardly changed from what was used on this rim-blow wheel:
    Under the center pad of the "good" wheel will be wiring and contacts to make a connection and blow the horn when the pad is pushed. Under the pad of the Fox-chassis version is just empty space.
  9. #8
    Join Date
    Jun 2003
    Location
    Salem, Oregon
    Posts
    6,975
    Smile
    I have the right wheel, then.
  10. #9
    Join Date
    Jun 2003
    Location
    Palmdale, CA
    Posts
    8,164
    The hard part is finding a good horn switch for thes Sport wheel. It was discontinued by Ford a long time ago, and used ones found in wrecking yards are usually very brittle and broken. These wheels can be found in Pintos, Mustang IIs, Granadas, big Cougars, Thunderbirds, some Mavericks I think and LTD IIs. Spokes can be brushed metal finish or black, the rim can be molded plastic or leather covered. The leather ones have a nice feel to them.
  11. #10
    Join Date
    Jun 2003
    Location
    Salem, Oregon
    Posts
    6,975
    Quote Originally Posted by yeloxr7 View Post
    This is the same wheel that I got from you Scott. I think I traded you an instrument cluster for it.
  12. #11
    Join Date
    Jan 2002
    Location
    Camano Island WA.
    Age
    64
    Posts
    3,874
    Blog Entries
    2
    When using this wheel on a 69 and earlier column the center of the wheel is a bigger diameter then the column.
    This is what one looks like on a 69 Column.
    This is what one looks like on a 70 Column.
    Hidden Content
    See ya on the hiways, Neal
    1970 XR-7 Hard top White & Ginger. 351W "Ginger"
    1970 XR-7 convertible Blue & Black 351C 4V The money pit.
    1971 XR-7 Bright Blue with Blue Up beat interior
    2015 Ruby Red Focus SE Daily driver.
    2006 Ranger Sonic Blue, 4.0 V6 5 speed AOD The work force.
    If it ain't broken, Modify it!
Thread Information
Users Browsing this Thread
    Similar Threads
    1. FOR SALE: 1967 Cougar Steering Wheel Assembly
      By Born To Prowl in forum 67-68 Parts for Sale
      Last Post: February 20th, 2011, 09:12 PM
    2. No difference between 16:1 manual and power steering boxes?
      By Born To Prowl in forum Classic Cougar Tech
      Last Post: July 11th, 2008, 03:31 AM
    3. Steering Wheel Help
      By homer in forum Cougar Community Discussion
      Last Post: October 27th, 2007, 06:00 AM
    4. '67 steering wheel plastic chrome ring replacement
      By Cougar-67 in forum Classic Cougar Tech
      Last Post: August 14th, 2006, 07:56 PM
    5. Steering wheel hight?
      By 1968_Cougar_Boy in forum Classic Cougar Tech
      Last Post: August 31st, 2005, 12:45 AM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
