428 PI vs. CJ
Results 1 to 13 of 13
Thread: 428 PI vs. CJ
  1. #1
    Join Date
    Mar 2005
    Location
    Kansas City
    Age
    43
    Posts
    255
    428 PI vs. CJ
    What are the diffrences between the 69 428 cj and the 69 428 PI. I have the opportunity to buy a 69 428 PI, but would like to put it into an original R code car. Is it worth it?
    '69 Standard Convertible Q-Code Auto
    '65 Buick Riviera Gran Sport
    '60 Cadillac Fleetwood 75 Limo w/divider glass
    '06 Chrysler 300 C SRT8
    '70 Buick Electra 225 Convertible
    '06 Dodge Ram 2500 Diesel (To Pull them all with!)
    '10 Ford Flex Limited EcoBoost
  2. #2
    Join Date
    Jul 2005
    Location
    Northern CA.
    Age
    58
    Posts
    108
    The heads are main difference they are of the garden varitey. The short block is the same. I would just value it as a short block myself.
    Also do your homework and use this as a componet identification guide. A lot of dressed up 390's have been sold as 428's over the years.
    http://www.428cobrajet.org/id-main.html
    70 Cougar Eliminator 428CJ/4spd
    Competition Orange With White Interior
    71 Ranchero GT 429CJ/Auto
    Grey Gold Metalic with Ginger Interior
  3. #3
    I didn't think they made a 428 PI in 69 but I've been wrong before. I know the earlier PI's didn't have the webbing in the block for the extra main support. If it has the aluminum intake on it that is better to have than the CJ intake. You can always buy better heads to put on it if you want. They are very worthwhile unless you wanted a CJ specific engine for a CJ car.
  4. Remove Advertisements
    MercuryCougar.net
    Advertisements
  5. #4
    If you have an original R code car and are going through all the effort to do it up I would spend the extra money to get the correct engine. At a minimum get a correct date coded block and perhaps the heads. You could do the rest (carb, fan, dist, etc) later if you choose.
    A.J.
  6. #5
    Join Date
    Mar 2002
    Location
    Dallas, Tx
    Age
    59
    Posts
    10,651
    The 428 PI was used through the 1970 model year. California appears to have made a large order of 1970 full size Mercury police cars in 1970 with the 428 PI engine. Engine code is "P" in the VIN.
    The aluminum intake on 428PI engines was discontinued around January 1968. After that the CJ type cast iron intake was used. Cylinder heads on the 428PI are the same as 352 / 360 and 390 low performance units.
    Royce Peterson
    CCOA MEMBER #590
    1968 GT-E 427 XR-7 Augusta Green / Saddle It looks all stock Heh - Heh
    1968 XR-7 428CJ Ram Air Red / Black / Black C6
    1910 Model T Ford Touring Red/ / Black
    1914 Model T Ford touring Maroon / Black
    1915 Ford Model "T" Touring.....Black / Black (of course)
    1917 Ford Model T Roadster Green / Black
    XR7-G Registrar
    CURBSTER Hidden Content
  7. #6
    That's what I like about this site. You learn new things all the time.
  8. #7
    Join Date
    Mar 2005
    Location
    Kansas City
    Age
    43
    Posts
    255
    Thanks for the help!
    Thanks of the help. You guys are really great! It is nice to be able to tap the wealth of knowledge here! If I may ask one more question. Would the C6 tranny that would be mated to the 428 PI be the same as the 428 CJ or are there differences there as well?
  9. #8
    Join Date
    Mar 2002
    Location
    Dallas, Tx
    Age
    59
    Posts
    10,651
    The tranny for a PI has a shifter arm that is upside down for a floor shifter since the cop cars all had column shift. It is not as beefy as the CJ transmission either and does not necessarily have a cast iron tail shaft although I am told some cop transmissions had them either by design or accident. You should be able to tell by looking.
    Royce Peterson
    CCOA MEMBER #590
    XR7-G Registrar
  10. #9
    Join Date
    May 2003
    Location
    New York
    Age
    54
    Posts
    657
    Carroll Shelby SEZ>>
    NO DIFFERENCE.......a quote from the man himself comparing how the KR car's where bringing so much more money than a GT-500. Mustang Monthly even rounded up a field of different FE powered cars for a chassis dyno----put-up or shut-up. The result's verified what Shelby stated! I have learned first hand from own expierence that "testing" and "tuned" can easily mean a 40-50 rwhp difference, so I think you would have to curve the result's. I don't think the CJ Block will give you anymore HP than the same component's on a passenger car block but it will certainly cost much more. From what I have learned unless you are going for a "numbers matching" trophy car put you're money into selecting good components, dynamic balancing and good tuning. I have CJ heads on a pass car block with FPA headers, an old F-427 intake topped with the original 735 cfm carb and it puts 318/385 to the rear wheels. The key here is the 385 ft lbs.......what fun! Mercinary....out
    "Blessed mother of acceleration dont fail us now" Elwood BluesHidden Content Hidden Content
  11. #10
    I had read what Shelby said about not being able to tell the difference between the 428CJ and the 428 PI. The block is not going to give you any more power but it is supposed to be stronger. I figured that the heads would flow better though.
    Royce or anybody else that knows; Did the PI blocks that were cast at the same time the CJ blocks were have the main webbing or did they continue to use the early style castings?
  12. #11
    Join Date
    Nov 2002
    Location
    Apple Valley, CA
    Age
    55
    Posts
    488
    Late 68, 69, and 70 PI blocks are the same as CJ blocks as are the cranks, rods and intakes. Most of the smog equipment is the same as a CJ as well as the air cleaner (except it does not have a chrome top) and snorkel. Most of the pulleys are the same as are all of the brackets. The pistons are different as are the heads, exhaust, ignition, carb. the heat stove and stube are different. Hawkrod
    Hawkrod
    39 Ford Deluxe Coupe
    59 Tbird 430
    (2)62 Tbirds
    (3)68 Cougar XR7-G's
    69 Cougar 428CJ 4 speed
    77 1/2 Ford Supercab F250 4X4 w/460 swap
    86 SVO mustang
    Hidden Content
  13. #12
    Thanks for the reply Hawkrod. Now if I could just find an old police car with the engine still in it.
  14. #13
    Join Date
    Dec 2005
    Location
    Alberta,Canada
    Posts
    181
    I ran a 428 pi engine in a 75 f100 4x4 with 427 medium risers many years ago,pulled great,but had to put a 361-391 truck 8 quart pan on it,as it used to suck the pan dry.Surprised many chickenhawk firebirds light to light with that truck.Would set c6 in second,put transfer case in low range,light up the 34 inch tires ,back off,ramm transfer case into hi and blast it to 75 mph in second before catching 3rd.at old airport strip in ft st john BC it ran 14.2/92 mph,which was pretty good for the mid seventies,and aerodynamics of a garbage truck.
Thread Information
Users Browsing this Thread
    Similar Threads
    1. 1970 428 cj
      By 69QcodeElim in forum The Den
      Last Post: March 25th, 2006, 10:14 PM
    2. Save Me!! 1969 "R" Code 428 Cougar
      By DroptopCougr in forum Cougar Community Discussion
      Last Post: February 25th, 2006, 02:00 AM
    3. 351 Cleveland or 428 !!!!!!!!!!!
      By sbeck in forum Cougar Community Discussion
      Last Post: November 8th, 2005, 09:52 AM
    4. X Quay 428 CJ No Reserve on Ebay NOW!
      By Dawsongrant98 in forum Cougars for Sale
      Last Post: September 20th, 2005, 06:44 PM
    5. Rare Cougars On eBay , 2 1968 428 CJ's
      By Solar Guppy in forum Cougars for Sale
      Last Post: September 7th, 2005, 11:56 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
