1970 COUGAR CONVERTIBLE
The first $10,000 cash will take this convertible home. I've got $16,000 in her but now need to move on. Please read below for details - you can drive this car anywhere, totally professionally mechanically redone, along with new paint. Just drove the Cougar over the weekend to Ojai & back - it hums. There is nothing to be done mechanically on this car, it has all been done.
351-Cleveland engine
4 barrel Holly carb
Power steering
Front Disc Brakes
Air-conditioning
Power top w/glass folding window
Eliminator Hood scoop & Eliminator Spoiler
This is a California blue plate Cougar, ready to drive anywhere. This is my 3rd vintage Cougar convertible, and this one gets more looks than my previous ones (one a 1st place National winner)...probably because of the deep metallic green color (w/camel boot & top - glass window) and the added Eliminator scoop & spoiler. The American racing wheels also add to the lines - a hot looking cat! The car has pretty much been all professionally, mechanically redone - totally new suspension, front end, exhaust system, engine rebuilt with only a few thousand miles (details below). The car is driving great - tight & powerful. Put in a new 4v Holly for the 351 Cleveland, and a super Dynomax Superturbos exhaust system - pricier than the Dynaflow, but I like it better - a 'performance' exhaust but a tad quieter, new on the market. Engine has had a major tune-up and transmission has received a full service, including replacing seals. Upgraded to Petronex electronic ignition & Halogen headlights. Also upgraded to front disc brakes - working great! Cooling system & Power steering system totally serviced, lifetime warranty on radiator replaced last year. New KYB shocks front/rear. Have all records for last 10 years. Car has air-conditioning.
Cat was painted a few months ago & interior seats redone. You can thoroughly drive & enjoy this car anywhere while working on cosmetic details.
REPLACED:
Lower/upper arms/ball joints
Spring seats
KYB Shocks
Spark plugs, air filter, fuel filter, ignition wire set, distributor cap, PCV, rotor, electronic ignition, ignition coil
Engine/transmission mounts
New rear leaf springs, shackles
Valve cover gasket set
New Oil pan & gasket
Speedo cable
Brake hoses/calipers/brake pads/wheel bearings/caliper hard wear kit
Alignment
Master Cylinder/brake booster/rear hose
Wheel seals
Tie rod ends
Coil springs set
4v Holly
Intake manifold
Upper A-arms bushing/shaft set
Sway bar bushings/links set
Rear main seal
Boot kit/power steering
Outer tie rod ends
Air conditioning service
Strut rod bushings kit
Steel brake lines
Rear leaf springs bushing
Battery cables
Fuel pump
AC idle step up motor
I can be reached at:
xr7gold@yahoo.com
310-455-0788
Photos available to view at:
http://pg.photos.yahoo.com/ph/xr7gold/album?.dir=/df6d
Larry
Bookmarks
