oval air cleaner fitment?
Results 1 to 13 of 13
Thread: oval air cleaner fitment?
  1. #1
    Join Date
    Dec 2004
    Location
    Denver, Co. USPS VMF
    Age
    51
    Posts
    7,476
    Well, a lot more has changed since I last posted, but in this case, it is all good news!
    I bought a house, with a garage, in the "country".....I really can't believe they were able to work the numbers to get me in the door...
    Anyway, I am almost done relocating my stuff, from the storage unit, to the house. I have started unpacking boxes that I packed up when I left Idaho, in October of 12. One of the things I had to look for, to find was my Cougar oval air cleaner. Now, I had previously installed an air gap on my 351W, and that set up was too tall for the air cleaner to fit. So, I found a Weiand "mid rise" intake, and installed it. I did a test fit yesterday, and sadly, still no fit :-(
    On the one hand, it's no big deal, as the car still isn't ready to run, but I would like to see it all together!!
    I know a lot of other guys are running that same air cleaner, with and without a hood scoop. Do you not have any spacer's between the carb and the intake, in order to make it fit? When I try to close the hood, it looks like I am just catching the forward 2 inches or so, of the oval....
    67 XR7, 68 5 SP, 69 5 speed build in progress Hidden Content Hidden Content
    *Disclaimer!! All info provided by the woodsnake is free, and worth what it costs!! Use with caution*
    What can I say, I like Cougars...
    " yer darn right wow "
    All my projects, pictures and audio clips.
    Hidden Content
    "Time to let the Cougar loose" R.B.
  2. #2
    Join Date
    Dec 2004
    Location
    Age
    51
    Posts
    7,476
    Re: oval air cleaner fitment?
    Also, does anyone have a picture of a hole in the hood/scoop with the same air cleaner installed?
    Hidden Content
  3. #3
    Join Date
    Nov 2013
    Location
    Belgium
    Posts
    322
    I don't have an oval air cleaner, but a triangle (wich comes forward a bit too), so I had to trim the hood a bit to make it fit, see pic:
    My hoodscoop was installed by PO, so I'm not sure if it was in the correct spot (it was also a bit sloppy).
    Luckely with the scoop on it's not visible:
  4. Remove Advertisements
    MercuryCougar.net
    Advertisements
  5. #4
    Join Date
    Dec 2004
    Location
    Age
    51
    Posts
    7,476
    Thanks for posting those. My younger son cut out the hole in my hood at school, now several years ago. It fits a round air filter fine, and that is what I have been using, but I really, really want to get the oval on the car!
    I will try and post some comparison shots later this week.
    Hidden Content
  6. #5
    Join Date
    Mar 2002
    Location
    Dallas, Tx
    Age
    59
    Posts
    10,651
    The cast aluminum bases on the oval air cleaners are too tall with most aluminum intakes on a 351 or FE. You can either cut the base down or get an original style sheet metal base from one of the better part vendors. See the Mustang catalog on page 130 item C5ZZ 9600-M. I was able to buy just the base, I bet you can too if you call:
    http://www.classicautopartsonlinecat...kCode=mus16flx
    Royce Peterson
    CCOA MEMBER #590
    1968 GT-E 427 XR-7 Augusta Green / Saddle It looks all stock Heh - Heh
    1968 XR-7 428CJ Ram Air Red / Black / Black C6
    1910 Model T Ford Touring Red/ / Black
    1914 Model T Ford touring Maroon / Black
    1915 Ford Model "T" Touring.....Black / Black (of course)
    1917 Ford Model T Roadster Green / Black
    XR7-G Registrar
    CURBSTER Hidden Content
  7. #6
    Join Date
    Dec 2004
    Location
    Age
    51
    Posts
    7,476
    Thanks for posting that Royce! I will get some pictures, and try to get a decent image for some measurements..
    Hidden Content
  8. #7
    Join Date
    Dec 2004
    Location
    Age
    51
    Posts
    7,476
    Hidden Content
  9. #8
    Join Date
    Nov 2013
    Location
    Belgium
    Posts
    322
    It looks like in your pictures you would have to trim the "crossmember" a bit?
    In my case had to trim a bit away from where the 2 pieces of sheetmetal merge, but did not have to cut in the actual reinforcement itself.
  10. #9
    Join Date
    Mar 2002
    Location
    Dallas, Tx
    Age
    59
    Posts
    10,651
    You have a 1" spacer under the carburetor. Replace that with a thick paper gasket for starters. The PCV can connect directly to a port on the intake.
    Royce Peterson
    CCOA MEMBER #590
    XR7-G Registrar
  11. #10
    Join Date
    Sep 2013
    Location
    ND USA
    Age
    53
    Posts
    1,761
    I know for a fact Weiand Mid rise intake will not work with stock hood on a 1967 with a 351 W
  12. #11
    Join Date
    Dec 2004
    Location
    Age
    51
    Posts
    7,476
    I've thought about a thinner carb spacer, but at the same time, I don't have a lot of room 'over' the MSD cap..
    Hidden Content
  13. #12
    Join Date
    Mar 2002
    Location
    Dallas, Tx
    Age
    59
    Posts
    10,651
    The photos make it look like there is more than 1" between the air cleaner and the MSD cap. Also, MSD offers a low profile "crab" cap that will save another inch if needed.
    Quote Originally Posted by woodsnake View Post
    Royce Peterson
    CCOA MEMBER #590
    XR7-G Registrar
  14. #13
    Join Date
    Dec 2004
    Location
    Age
    51
    Posts
    7,476
    Well, I pulled the spacer out from under the carb this evening, and still no joy! I looked at the 'crab' cap for my MSD, and only see a cap for a crank trigger style dist.
    This one of those things that really makes me want to quite. I mean, am I going to have to spend another thousand to make this thing fit?????
    Hidden Content
Thread Information
Users Browsing this Thread
    Similar Threads
    1. Cougar oval air cleaner fitment issue with export brace
      By RayH in forum Classic Cougar Tech
      Last Post: June 19th, 2014, 11:27 PM
    2. Cougar oval air cleaner
      By Four-55 in forum 71 & Up Parts for Sale
      Last Post: June 23rd, 2009, 03:34 PM
    3. Cougar oval air cleaner
      By Four-55 in forum 69-70 Parts for Sale
      Last Post: May 9th, 2009, 07:55 PM
    4. Cougar oval air cleaner
      By Four-55 in forum 67-68 Parts for Sale
      Last Post: April 11th, 2009, 10:00 PM
    5. Cougar Oval Air Cleaner Question
      By jshcobra in forum Cougar Community Discussion
      Last Post: March 29th, 2007, 08:26 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
