Car won't start, have spark, fuel in floatbowls
Results 1 to 6 of 6
Thread: Car won't start, have spark, fuel in floatbowls
  1. #1
    Join Date
    Nov 2013
    Location
    Belgium
    Posts
    332
    Hi guys, got a bit of an annoying problem.
    The car sat for a month or 2 and doesn't want to start on it's own. It does start however when I prime the carb with fuel or spray it with carb cleaner.
    After that it runs great and idles like it should.
    However when I turn the car of and try to restart, nothing happens, not even a slight attempt.
    So I have spark, timing is still good, i already opened the fuel bowls (the carb is a HOLLEY 600cfm vacuum secondaries btw, 2 years old).
    But they were clean as a whistle, also the floats are working.
    When the car is not running and I operate the throttle, there is no fuel squirting down the carb like it should?
    Before I start disassembling the entire carb, anyone has any idea where to start looking?
    I suspect something is clogged somewhere, but it's not the main jets, and the idle quality is fine too.
    I didn't feel anything out of the ordinary when driving, accelerating hard from a stop etc... nothing feels off once running.
    Any help or hints would be much appreciated
  2. #2
    Join Date
    Sep 2013
    Location
    ND USA
    Age
    53
    Posts
    1,763
    Re: Car won't start, have spark, fuel in floatbowls
    check ball above accelerator pump diaphragm or check ball bellow discharge nozzles are plugged ...
    http://www.tocmp.com/manuals/Carbs/H...lB150_0008.htm
    you need to look at putting some fuel conditioner in your fuel as these are all signs of your fuel destroying your carburetor ...
  3. #3
    Join Date
    Nov 2013
    Location
    Belgium
    Posts
    332
    Ok thx, i'll look into it. I'll let you know what I find
  4. Remove Advertisements
    MercuryCougar.net
    Advertisements
  5. #4
    Join Date
    Jun 2003
    Age
    54
    Posts
    757
    Hello hanver, ndtorque is on target for troubleshooting your carb... sounds like the accelerator pump is clogged or not working correctly. Sta-bil is a good and reliable conditioner that can be added to fuel during storage.
    Here's a couple links: http://sta-bil.co.uk/ or: https://www.goldeagle.com/brands/sta-bil
  6. #5
    Join Date
    Sep 2013
    Location
    ND USA
    Age
    53
    Posts
    1,763
    "Mechanic in a bottle " is the product I would recommend
    http://b3cfuel.com/products/mechanic-in-a-bottle
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  7. #6
    Join Date
    Nov 2013
    Location
    Belgium
    Posts
    332
    Hi guys
    Think it's fixed!
    Opened up the acceleraterpump en my carb version has a flat checkvalve, not a ball checkvalve, see pic:
    (Don't mind the rubber caps on the vacuumports, somehow mine deteriorate very fast, like in I have to put new ones on every 6 or so months?)
    My checkvalve had come undone from it's position (only held on by a small rubber tab???), pushed it back in place, buttened everything up and remounted the carb to the engine.
    After starting it the first time, I turned the car off, let it sit a few min and try to restart, and it did.
    Went for a drive, and at the gas station also no issue's restarting, so I'm hoping it's fixed
    Thx for the pointers!
Thread Information
Users Browsing this Thread
    Similar Threads
    1. No spark? Won't start?
      By Lovin_cougars86 in forum Classic Cougar Tech
      Last Post: December 31st, 2016, 04:36 PM
    2. Car won't start!
      By Sgt.Pepper in forum Classic Cougar Tech
      Last Post: October 30th, 2008, 12:50 PM
    3. Car won't start.
      By JoeXR7F93C in forum Classic Cougar Tech
      Last Post: August 2nd, 2008, 09:49 PM
    4. Help Car Won't Start
      By 390XR7 in forum Classic Cougar Tech
      Last Post: November 20th, 2005, 07:32 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
