8.8 Swap?
Results 1 to 8 of 8
Thread: 8.8 Swap?
  1. #1
    Join Date
    Mar 2013
    Location
    Beaufort, SC
    Age
    27
    Posts
    41
    8.8 Swap?
    Here's the skinny. '68 8" is 59.25 inches wide. 2001 Expedition 8.8" is 63 inches give or take half an inch. Can I make up the difference with backspacing on the wheels or would it have to be cut down to 59 inches in width and why?
    Hopefully this is an easy question to answer as I am trying to either keep or off load this rear end in the next 6 hours.
    Thank you in advance for any info!
    '68 XR7 Maroon, Building 408W Hidden Content
    2013 F-150 Plt White SuperCrew 4x4, to tow the cat while working on 'er Hidden Content
    "Life is hard, but it's harder if you're stupid" - John Wayne
  2. #2
    Join Date
    Aug 2012
    Location
    Saint Helens, Oregon
    Age
    45
    Posts
    680
    Re: 8.8 Swap?
    Yes, you can make up ~2" with backspacing, no you do not need to cut it down unless the offset pumpkin hits the floor pan/trans tunnel.
    I have not heard of an Expedition 8.8 swap, I however cut my Explorer 8.8 down on the long side to accept a short side axle (FREEBIE). This centered the pumpkin and gave me a ton of room to run a deep rim and wide tires on my 67.
    Hope that helps a bit...
    "Hell I dunno... I cut it three times and its still too damn short..."
    "It's not a flaw, it's a feature..."
    Built NOT Bought...
    Hidden Content Originally Posted by ndtorque Hidden Content
    some people can screw anything up .... without trying ....
  3. #3
    Join Date
    Mar 2013
    Location
    Beaufort, SC
    Age
    27
    Posts
    41
    Re: 8.8 Swap?
    That's the same thought process I had. I did however get rid of the Expedition 8.8 and going to a localish junkyard to hopefully find an explorer one since it's 1000x easier to find info on those. If you don't mind sharing do you run the stock size 11" I believe disc up front and 11" explorer rear disc at the same time?
  4. Remove Advertisements
    MercuryCougar.net
    Advertisements
  5. #4
    Join Date
    Aug 2012
    Location
    Age
    45
    Posts
    680
    Re: 8.8 Swap?
    Im running 2015 Mustang GT 13.2" fronts and the stock 96 Exploder rears on the Panther and 70 Mustang disks on the Roadkill. Once it gets the Exploder rear Ill keep it full length and run the factory disks as well... Panther is setup for street and road courses while Roadkill will see sand and loose dirt with some street action to and from the trails/dunes.
    Built NOT Bought...
  6. #5
    Join Date
    Aug 2011
    Location
    Chesapeake Va
    Age
    50
    Posts
    540
    Re: 8.8 Swap?
    screamin_67, what width tires are fitting on the back?
    Andy
    ____________________________________
    '68 STD
    '71 302 Block/'69 Heads
    Performer RPM
    600 cfm Holley
    '68 C4
    Hidden Content
  7. #6
    Join Date
    Aug 2012
    Location
    Age
    45
    Posts
    680
    Re: 8.8 Swap?
    Hey Andy... Panther is currently sitting on 18x9.5 5" BS Boss 338 rears with a 275/35/18 tire. I have fit my buddies 295/30/18 rears on her without issue, same wheel, but spacers are needed to correct the backspacing. I am going to do a mini tub on her to try and fit Nitto 315s for track purposes. After I destroy the 275s Ill be running 295s on the street with a custom backspacing.
    Roadkill will be running a full length Exploder 8.8 with 31/10.5/15 MTs on a 15x8 3.75 BS Pro-comp rim BUT she has re-arched and flared quarters planned and will be running enough lift that the tires will not be an issue in the rear.
    I just need to win the lottery, this new job is really zapping my "play time"
    Built NOT Bought...
  8. #7
    Join Date
    Aug 2011
    Location
    Chesapeake Va
    Age
    50
    Posts
    540
    Re: 8.8 Swap?
    Great! Thanks. I have my 8.8 all cut down and ready to install after I fix some rust issues back there.
    Andy
    '68 STD
    Performer RPM
    600 cfm Holley
    '68 C4
    Hidden Content
  9. #8
    Join Date
    Dec 2003
    Location
    Norway
    Age
    45
    Posts
    2,672
    Re: 8.8 Swap?
    I had a set of 338's 18X9.5 with -4 mm offset on a stock 68 8" rear, noo problems, but if you are putting in a wider rearaxle, then more backspacing will be needed.
    The best thing to do, is get the axle mounted, then measure what width and backspacing you want to suit your car and likings
    `68 XR7
    CCOA member # 7457
    Cascade Cougar Club
    Mercury Club of Norway
    AMCAR (American Car Club of Norway)
    AAHHH, there`s nothing like the smell of highoctane fuel and burning rubber in the afternoon
    When i`m not here, i`m sitting on Hidden Content
    Hidden Content
    Hidden Content
Thread Information
Users Browsing this Thread
    Similar Threads
    1. 67 t5 swap
      By 67mercman in forum High Performance
      Last Post: January 7th, 2010, 03:14 PM
    2. T5 swap - On my way
      By wout67cat in forum Classic Cougar Tech
      Last Post: September 6th, 2009, 03:25 PM
    3. T5 swap ???s
      By 69Hcode in forum Classic Cougar Tech
      Last Post: October 26th, 2006, 01:28 PM
    4. T5 swap ???s
    5. T5 swap
      Last Post: October 13th, 2006, 09:47 AM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
