70 XR7 switches
Results 1 to 7 of 7
Thread: 70 XR7 switches
  1. #1
    Join Date
    Sep 2005
    Location
    chicago area
    Posts
    223
    70 XR7 switches
    70 owners, the 4 switches in the dash (map courtesy panel accy) are they hot all the time or does key have to be on? I want to use the accy for a remote trunk release but I want it hot all the time. Thanks, CS
  2. #2
    Join Date
    Jan 2002
    Location
    Camano Island WA.
    Age
    64
    Posts
    3,819
    Blog Entries
    2
    Re: 70 XR7 switches
    The accy has no wires to it at all. The others are for interior lights and do have power to them. I would run a new wire from the fuse box or hot side of the starter solenoid under the hood for this. Use a in line fuse near where you pick up the power. The potential problem is usually a switch for a trunk lock would ne a Momentary contact switch. Meaning it is spring loaded and when you take your finger off it it will return to the off position.The switch in the accy position is just an on and off switch. You may be able to insert a window switch in the the bezel and have it work this way. Let us know how this works for you. I can't use it as I have a rear defogger in my hard top and my convertible uses that switch for the top.
    Hidden Content
    See ya on the hiways, Neal
    1970 XR-7 Hard top White & Ginger. 351W "Ginger"
    1970 XR-7 convertible Blue & Black 351C 4V The money pit.
    1971 XR-7 Bright Blue with Blue Up beat interior
    2015 Ruby Red Focus SE Daily driver.
    2006 Ranger Sonic Blue, 4.0 V6 5 speed AOD The work force.
    If it ain't broken, Modify it!
    Hidden Content Hidden Content
  3. #3
    Join Date
    Sep 2005
    Location
    chicago area
    Posts
    223
    Re: 70 XR7 switches
    Thanks Badcat, I did some rework on that switch to make it a momentary switch, let off and it shuts off. I wired it in a few months ago but got to wondering if it was live or needed key power. The car is still in pieces so I can't just test it.
  4. Remove Advertisements
    MercuryCougar.net
    Advertisements
  5. #4
    Join Date
    Jun 2003
    Age
    54
    Posts
    743
    Re: 70 XR7 switches
    I've used the Wirthco 30200 fuse block taps for adding assy power. Here's the web link: http://www.wirthco.com/pdf/Fuse%20Ta...%20Holders.pdf Also, our local "non big-box" auto parts store stocked them, so probably easy to obtain.
  6. #5
    Join Date
    Sep 2005
    Location
    chicago area
    Posts
    223
    Re: 70 XR7 switches
    Thanks Katnip, That looks like a good idea. I also have a newer radio that needs full time hot wire for memory. I looked and the local Napa has them.
  7. #6
    Join Date
    Nov 2004
    Location
    NJ
    Age
    57
    Posts
    13,365
    Re: 70 XR7 switches
    Quote Originally Posted by cougstang View Post
    That's a fine idea. I mounted the factory type pushbutton switch (from a later model car as the electric latch was) in/on the underside (horizontal surface) of the lower dash so it is hidden but easy to find, right above the drivers right knee/leg.
    Isabel: The realization of a seven year long dream:
    Hidden Content
    Hidden Content
    Canted--Texan on the351cforum: "One of my most impressive attributes is that.......a lot of people don't like me.....or the horse I rode in on"
  8. #7
    Join Date
    Feb 2007
    Location
    Austin, TX
    Age
    52
    Posts
    398
    Re: 70 XR7 switches
    Just an FYI, Window switches are bigger than the switches in the dash switch bezel so are not interchangeable.
    1970 Mercury Cougar XR7 Convertible
    1973 Ford Mustang Convertible
    1998 GMC Sierra K1500 4WD pickup
    2007 Toyota Prius
    1986 Toyota SR5 4WD pickup
    1998 Suzuki Intruder 1400
Thread Information
Users Browsing this Thread
    Similar Threads
    1. Three 1967 XR7 Toggle switches
      By 1968_Cougar_Boy in forum 67-68 Parts for Sale
      Last Post: August 23rd, 2006, 10:54 PM
    2. Need two black XR7 Toggle Switches
      By 68 MERC in forum Parts Wanted
      Last Post: August 2nd, 2006, 03:46 PM
    3. XR7 panel switches
      By DavidF in forum Cougar Community Discussion
      Last Post: March 25th, 2005, 02:40 PM
    4. 69/70 xr7 toggle switches
      By ViCatz in forum Parts Wanted
      Last Post: April 3rd, 2004, 10:24 PM
    5. Looking for '68 XR7 dash switches...
      By Willie Wonka in forum Classic Cougar Tech
      Last Post: February 1st, 2004, 11:35 PM
    Bookmarks
    Posting Permissions
    • You may not post replies
    • You may not edit your posts
